a/c not blowing cold. code 43???
Old 08-10-08, 06:35 PM
818sc400
818sc400's Avatar
Default a/c not blowing cold. code 43???
my a/c is not working properly i recently refilled it. it was blowing cold for 1 month all of a sudden it stopped and now im get a code 43. anyone know how to fix this issue???
Old 08-11-08, 07:43 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
https://www.clublexus.com/forums/sho...+trouble+codes
Old 08-11-08, 07:45 AM
mitsuguy
mitsuguy's Avatar
From my post above, air outlet servo motor malfunction
basically one of the doors behind the dash is stuck or not working...
Old 08-11-08, 08:41 AM
818sc400
818sc400's Avatar
thank you sir!
do you have any idea how much this would cost to get fixed?
Old 08-18-08, 05:27 AM
lexluger71
lexluger71's Avatar
okay , i am getting code 21 and 24, how do i fix this issue, where is the solar sensore located, and how much to repair it. and what is code 24?
Old 08-18-08, 05:37 AM
mitsuguy
mitsuguy's Avatar
no clue on code 24, it's simply not listed... 21 - solar sensor - without looking it up, I believe it is the sensor that is mounted on the drivers side of the dash up by the windshield...
Old 08-18-08, 05:53 AM
lexluger71
lexluger71's Avatar
well this is a 2001 gs 300, i don't know if there are different. i also have the heater oxygen sensor code coming on, i wonder if that will activate the cde 24. the solar sensor does the das have to come off for that. i just tried the code and it's like 76 degrees where i am at.
Old 08-18-08, 06:34 PM
mitsuguy
mitsuguy's Avatar
Originally Posted by 818sc400
thank you sir!
not a clue...
Old 08-19-08, 03:48 AM
VVT-i
VVT-i's Avatar
Code 21 and 24 Solar sensor alway there for all the ac system. The brand new LS460 will have two ac codes that you can't clear and Lexus said don't worry about it.
Calin72
Hybrid Technology
03-29-19 11:50 AM
Fritz330
07-03-16 07:45 PM
bkalweit
08-12-12 11:11 PM
wrpsuite
07-26-08 08:02 AM
Quick Reply: a/c not blowing cold. code 43???
