Just what exactly is inside that oil filter?
Former Sponsor - Cancelled
As requested the AMSOIL EaO57 oil filter for 1997 SC 400 1uzfe
![](http://c3.ac-images.myspacecdn.com/images02/39/l_a179253028ef461a85cacea94fdee972.jpg)
![](http://c3.ac-images.myspacecdn.com/images02/15/l_95a548037fdf405687ed69be7300872a.jpg)
![](http://c3.ac-images.myspacecdn.com/images02/42/l_9c20ac7273724e2499c1bfb129855f3e.jpg)
![](http://c3.ac-images.myspacecdn.com/images02/39/l_3f90a4d9b576465190dd890b1ba88076.jpg)
![](http://c3.ac-images.myspacecdn.com/images02/61/l_9496c520c7154c2f87787fde3f626842.jpg)
![](http://c4.ac-images.myspacecdn.com/images02/46/l_8ce8fdebb7f74fd289c000eb3743472f.jpg)
![](http://c2.ac-images.myspacecdn.com/images02/18/l_c4d453733ba04a898fa5f5fc6c73e579.jpg)
![](http://c2.ac-images.myspacecdn.com/images02/35/l_6198c0dfabe148aeab333a88a2f6c415.jpg)
![](http://c4.ac-images.myspacecdn.com/images02/56/l_c694b75256854af7a78b23075b26fe03.jpg)
As you can see, its a nice filter on the inside. Full metal construction for the filter element (besides the filter media). Silicone Anti drain back valve that stays flexible in extreme temperature. HNBR gasket on the base for long life and a great seal. Hardcore Bypass valve assembly. Wire backed full synthetic media has high efficiency and good life. Rated 98.7 % efficient at 15 microns.
djspawn00: I will check on the mobile 1 filter as soon as I get a chance
If you do OE, make sure it's the 90915-20004 Toyota Denso filter. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
I've never used anything but that filter, and Mobil1 Synthetic.
http://www.l-tunedparts.com/product/?id=2217
I'm actually getting an oil change again, and I've noticed that when I start up the car (I'm running the K&N gold) I have to hold the key in the "on" ignition slightly longer for the engine to start, whereas other people's cars turn it on and it'll start. I heard that it has something to do with the oil filter, and that the OEM ones do not cause the engine to do that. Now, why is the Denso one so much better then the OE Toyota ones? Also, is the Denso better then the Amsoil? I regularly maintain the car, and I really do not know what the oil filter does other then ... filter the oil. All this talk about microns, etc. is kind of confusing me, enlighten me please, but I will just google this anyways.
All an oil filter does, is, well, filter the oil, just like you said... a micron is a unite of measurement, quite small indeed - filters can be measured in how well they filter our particles in the oil, these particles are so small they are measured in microns wide...
If your car is taking a little longer to start than usual, could be a slightly weak battery, starter, or, just one of those things... (one of those things could be a slow to respond sensor, or a multitude of other things that you needn't worry about until it gets worse)
Plus perhaps a combination with winter weather. All things being equal, that colder temps might have an effect on a lot of your car's operation, but related to starting up, perhaps most noticeably the output of your battery and maybe to some degree the volatility of fuel. Doesn't mean anything is wrong with your car
gabzor
23
12-05-15 01:50 AM
Baybarea
04-07-08 06:06 PM
Och
12-27-05 02:52 PM
