power steering noise (HELP)
I have a 1994 lexus es 300,I can hear the power steering whining a little but my fluid smells burnt.is my pump going bad or should I just change the fluid.I have no problem steering it feels great.
Drain and fill the fluid first.
Then check for noise, most power steering systems whine either becuase there is a restriction in the system... Like a clogged filter/screen or because the fluid level is low.
You can also use the advanced search function and select the ES forum to get more detailed info.
ls430lover
08-02-14 08:11 AM
trips1
RX - 1st Gen (1999-2003)
09-13-09 07:15 AM
MoogieBoogie
Performance & Maintenance
13
08-04-06 07:39 PM
