Transmission - 98' SC300
Old 10-31-08, 12:05 PM
burnsSC300
burnsSC300's Avatar
Default Transmission - 98' SC300
Hi everyone,
My transmission is acting up. It's "racing" up in the RPM's and falling down too low as well. I know it is in need of a fluid change. It's at 123,000 miles.
Should I change the fluid and see if it helps or take it right to the shop?
Thanks.
Old 10-31-08, 01:30 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
I would definately check the fluid and see if its low and/or burnt. If its just low, you may be able to solve the problem. Likely though, you probably have a fried transmission.
maurice01
11-24-19 02:48 PM
cal_alum98
Maintenance
03-14-14 12:53 AM
ls40092
15
02-01-14 11:30 PM
305ls400
11-06-13 04:48 AM
gapxguy
Maintenance
18
04-08-05 08:27 AM
Quick Reply: Transmission - 98' SC300
