2000 Lexus GS 300 - A/C stuck on High
My A/C/Heater is stuck on High. The climate control unit moves up and down, but regardless if I put the A/C on low through high, it blows at the highest setting. I believe I changed the blower motor relay correctly (removed the glove compartment and changed the big black relay on the passengers side panel. Once replacing it, the same problem exists. Any help would be much appreciated.... Everything is still torn apart, so should be easy to test.
Thank You!!!
Thank You!!!
