Needing help on error codes
Old 01-13-09, 03:18 PM
pestleman0
pestleman0's Avatar
Default Needing help on error codes
Can anyone tell me what these error codes mean?
EMV:
01-DC 190-4A-3
01-D8 190-47-1
01-D5 190-61-8
Nav:
01-E3 000 FF-3
Where can I look to see what these codes mean other than contacting dealer? Any help is greatly appreciated. 07 ES350
Old 01-13-09, 03:27 PM
VVT-i
VVT-i's Avatar
Those are navigation/audio codes. What's wrong with the system? Nobody really know about those codes unless you're Lexus engineer.
Old 01-13-09, 03:38 PM
pestleman0
pestleman0's Avatar
The only issue that I have noticed is with Bluetooth. Everything else appears to be ok. Of course, if it is throwing codes I would like to know what it is so that it can be addressed depending on what is going on.
Old 01-22-09, 06:26 AM
aasc300
aasc300's Avatar
I have looked up the codes for you in TIS
01-DC 190-4a-3 = Transmission error radio reciever
01-D8 190-47-1 = No response radio reciever
01-D5 190-61-8 = Absence of registration unit
One of two things:
Radio unit is bad
or
Radio connection was lost with ignition on (IE radio plug loose or radio was unplugged with ignition on)
The nav code is set because of the radio code.
Old 01-27-09, 09:08 PM
pestleman0
pestleman0's Avatar
One of two things:
Radio unit is bad
or
I can't thank you enough for your time. Will have to bring it to my dealer's attention on next oil change which is coming up soon. Is this something that could have occured at the factory when assembling the car? Should I suggest having them replace the radio unit? I'll bring it to their attention and see what they say. Any thoughts?
Old 01-28-09, 04:07 AM
aasc300
aasc300's Avatar
There could be a bent PIN in one of the radio connectors. Has your dealer had the dash apart or the radio out for any reason? Has the sound system ever blown a fuse while the car was on?
Old 01-28-09, 08:10 AM
pestleman0
pestleman0's Avatar
The dash has never been apart. The only thing done to audio system was replacing back speaker due to vibration. Never blown a fuse to my knowledge.
Old 01-28-09, 07:53 PM
pestleman0
pestleman0's Avatar
Now it's giving me:
DSP-AMP
01-DD 110-80-3
Any idea?
Old 01-28-09, 08:35 PM
pestleman0
pestleman0's Avatar
Something I just remembered was the dealer replaced the entire glove box assembly due to the button being stuck at times. It might be possible they took out the radio unit to do this.
Old 01-29-09, 05:38 AM
aasc300
aasc300's Avatar
That code refers to the master audio unit loosing power or being disconnected with ignition on. If they had the glovebox out there is a strong chance that they may have loosened a plug on accident or disconnected unit while the ignition was on....... Hope this helps.
Old 01-29-09, 10:35 AM
pestleman0
pestleman0's Avatar
Yes. You have been a tremendous help.
Old 01-30-09, 07:21 AM
aasc300
aasc300's Avatar
If you need anymore help, just let me know.
AssafZi
08-13-18 02:17 PM
SteveSC400
03-26-08 07:36 PM
mikeyis300
04-21-04 09:07 AM
Quick Reply: Needing help on error codes
