1992 SC400 A/C Compressor RELAY Location??
Maintenance Moderator
It's in the fuse box in the engine compartment...
If you are looking at the fuse box with the small fuses running horizontally with the large fuses above them, then the A/C relay would be to the right and in line with the large fuses - there are two relays in that corner in line with the large fuses - one is the EFI relay and is smaller, the A/C relay is between the EFI relay and the large fuses...
Segzy14
07-18-18 01:00 PM
bigwes
SC- 1st Gen (1992-2000)
05-20-13 02:28 PM
