ABS ECU location.
ABS ECU location.
1990 LS400 w/trac.
I wanted to know where the ABS ecu is located. because after checking all the sensors for a code 35, the lights of trac off and abs is still not going away. So i plan on swapping the ABS ECU to see what that does.
I tried to reset codes using the methods described. It says to jump the TC and Te1 and to take the jumper pin off.
the only place I found the jumper pin was on the far right side of the hood under a plastic cover. Is that the correct jumper pin used to reset the codes ?
thanks in advance. !
