a question for you oil gurus
The higher the weight, the thicker the viscosity. Lower the weight, the thinner the viscosity. The first weight number indicates how viscous the oil is when in its cold state, and the second number indicates the viscosity when the oil is hot.
So that oil you're using (10w-40) is a lil bit thicker than 5w-30, in cold and hot state. Thicker oils can bog the engine down a lil bit, IMO just run what is suggested next time. Running 10w-40 won't break anything, it's just a bit more thicker than what's recommended.
Actually, it's a little more complicated than that... in a 5W-30, the 5 is based on how thick or thin it is, the 30 is how much "stickiness" it has in comparison to straight weight oils... in essence, a 5W30 flows like a 5 weight, but has the protection of a 30 weight...
I was using a synthetic 5W-40 in my SC400 and it seemed to be too thin because the oil sump pan showed a bit of seepage and I could occasionally smell the oil through the vents. I was thinking of switching to Redline 10W-40 here in WA... What do you all think?
Yeah I know they do, but can't an oil eventually seep out if it's TOO thin? My buddy said switching to a heavier weight may help a bit, but wasn't guaranteeing anything. I figured it would be worth a shot, but just don't want to put TOO think of an oil in, ya know? Think 10W-40 is too much for a cooler climate?
The best weight oil to use is the lowest weight oil that is within OEM recommendation. Let me explain; up to 80% of engine wear is from cold starts. This does not only pertain to cold weather. Cold start means the first start of the day after the engine has completely cooled/drained down. This wear accrues in the time the oil takes to get to the vital parts of the engine (bearings, cams, lifters, etc). The quicker the oil gets to those vital areas the less wear. That being said, the lower the weight the better/faster the oil will flow during start-up. The IS, along with most modern engines are using 5w-20. The “w” represents winter and is the important number to look at when determining cold start flow. The lower the number the better cold flow. I personally use 0w-20, which is within OEM specs. There is no need to use 30 weight oil in the IS engine, but it will not hurt the engine. If you feel better using 30 weight oil go with the 0w-30. Any of the top brand synthetics are overkill especially if you are changing your oil in less then 10,000 miles. If you are using quality synthetic oil and a quality oil filter you can safely use a 10K mile OCI, anything less is a waste time and money. For the IS, 10K miles or one year is the rule of thumb.
Koz
Koz
To answer your question; Grade/weight of oil – Viscosity (flowability) is how to measure the shear strength of a thin layer of oil. A bearing works by using a thin layer of oil not by the oil pressure generated by the pump. If you use too high a weight oil the layer will not form fully or may not get into the bearing at all. If you use too low a weight the layer will not give the bearing the proper protection. Bottom line, make sure you stay within the manufactures recommended ranges.
Koz
Koz
one thing to consider is getting your oil analyzed by a lab like blackstone. it's only like $22 and they tell you how your engine is wearing, how much longer that oil coudl have protected your engien and recommend an approximate oil change interval based on the results. many people change their oil way too often in these days of superior oil technology and better engineered and built engines.
Klymbort
06-05-17 03:47 PM
sleepybobcat
RX - 1st Gen (1999-2003)
02-28-02 02:43 PM
