what componets usually fail/need to be changed b/t 60-90k miles?
Old 02-22-09, 04:49 PM
handoverfi
handoverfi's Avatar
Default what componets usually fail/need to be changed b/t 60-90k miles?
power steering pump? water pump? timing belt? spark plugs? lower ball and upper ball joints? tie rods? window or door lock regulator?
add anything to the list. like the most common parts that fail when the millage starts getting up there.
Old 02-22-09, 05:09 PM
GSteg
GSteg's Avatar
everything will more likely fail once you rack up the miles. I say it depends on the car. Some cars dont have problems with door lock actuators or balljoints ever. Water pump, timing belt, and spark plugs are maintenance items. They should be replaced eventually.
Mike234588
05-08-17 07:50 PM
vnairp11
04-24-13 08:54 AM
Chocolate
01-02-13 06:10 AM
cmara2k9
02-24-11 10:11 AM
voleduy
IS - 1st Gen (2001-2005)
01-11-11 06:32 AM
Quick Reply: what componets usually fail/need to be changed b/t 60-90k miles?
