Trac light won't go off???
MY TRAC BUTTON WHEN PRESSED IN ANY GEAR WITHOUT THE ENGINE ON WILL TURN THE INDICATOR LIGHT OFF FROM THE CLUSTER BUT ONCE I SHUT OFF ENGINE AND START IT AGAIN AFTER A FEW SECONDS THE TRAC OFF LIGHT RE-APPEARS ON THE CLUSTER... I GOT THE CODE READ AND THEY SAID IT WAS EITHER THE CONNECTOR TO THE ABS/TRAC ECU OR THE ECU WAS FAULTY..... WHERE CAN I FIND OUT MORE ABOUT WHERE THESE UNITS ARE LOCATED IN THE CAR??? HOW CAN I FIX THIS PROBLEM???
PLEASE HELP????![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
THANXZ
PLEASE HELP????
THANXZ
TURN OFF YOUR CAP LOCK FIRST. IT'S SEEM LIKE YOU'RE SCREAMING AT US FOR HELP...![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
WELCOME TO CL.
It will more helpful if you read the sticky and give some detail about your car, such as model, year, mileage, recent history,accident, mods, DIY...etc...
The ABS/Trac ECU located behind the dash, the ABS/Trac actuator located on the passenger side or driver side of the engine near the firewall depending on the vehicle year and model. I hope this will give you enough info for your further diagnostic.
WELCOME TO CL.
tiger326
06-09-17 08:32 AM
