Oil pan spacer
No its not a gasket its about 3" tall its aluminum and looks like it could be replaced mine has a big hole in it due to an accident and I really dont want to replace the whole engine I'll try to post pics when i figure out how to
Maintenance Moderator
I would say its unlikely... the book calls for 12.7 - 13.5 hours worth of labor time... (Motor or Chilton time)
essentially that's approximately how long it would take a skilled technician with all the proper tools and a lift to complete the job...
Now, same vehicle, to remove and install the complete engine is 15.3 hours... that means that the engine doesn't come out completely, and without looking it'd be hard to say for sure, but most vehicles that have low clearances like that for oil pan removal, you would disconnect the driveshaft, disconnect the motor mounts, move anything on top of the engine that would interfere with it moving such as air intake, etc, possibly loosen any hoses and wire assemblies, then use a engine hoist that goes across and sits just inside the fender - use this to lift and support the engine - should give you 6-10" of clearance, and enough to get the oil pan out of there... might ask one of the Lexus techs on here if there is a short cut, or if more might have to happen...
THANX RTIS250 I 'm sure I could do the work but I wanted piece of mind to let ASE certified shop do the work plus I get a guarantee with their work.
