Use of aftermarket brake pads on '06 GS300?
Hi all..
Well.. My '06 GS300 (owned for almost 4 years) is finally ready for new front pads after almost 25k miles. I've already redone the rears some time ago.. Not sure why the fronts lasted longer (backwards from what I've had with just about every other vehicle I've ever owned). Anyway, the local dealer wants >$90 for the front pads (just for parts) and I found an online dealer on the east coast for a bit over 1/2 that. Anyway, IF I go with aftermarket pads, what should I be looking for -- I gather I should avoid semi-metalic and go with either ceramic or organic.. The prices seem to be all over the place from poking around on RockAuto from $20 to $55.. If the 'good' pads are on the higher end then I might as well get the Lexus pads (mail-order). Anyway, I want something that will not wear down the rotors excessively fast.. Thx!
P.S. Is there anything to look out for when doing front pads on this vehicle? Thx!
For the $20 brake pads:
- sometimes squeaking noise
- don't last as long...perhaps, half the life of the more expensive ones
- if you are not racing and if you are doing the brake job yourself, the $20 brake pads will be fine
I'd go OEM - but if you want aftermarket pads, I've have great success with Australian-made PBR/Axxis pads - Rock Auto carries them as Beck-Arnley's Axxis line, 088 is the part prefix.
Stay away from Raybestos though - I've had no luck with them. A Nissan I used those on had to get new rotors, while a Honda I put those on squealed like a pig and ate through those in 3 months.
- BECK/ARNLEY Part # 0871657, Front; Semi-Metallic [Wholesaler Closeout -- 30 Day Warranty]
- BECK/ARNLEY Part # 0821657, Front; Premium
- BECK/ARNLEY Part # 0861657C, Front; Ceramic
I'm wondering now if I should just bite the bullet and buy the Lexus ones.. At least they're a known quantity with regards to lifespan,etc. I might have to think about this a bit more..
Thanks.. I just popped back on the RockAuto site and they only show prefixes of 82, 86, 87 with the following descriptions :
I'd try to punch in 088-1657D, 088-1657M or 088-1657U. IMO, I would stay stock. I also know Akebono and Aisin/ADVICS makes their pads available to the aftermarket - if you know someone with a WorldPac account they can get the Advics or Akebono white box pads which is the same as OEM. Akebono ProACT in the black and blue box is good too and easier to get.
I've had good luck (98%+) with the Wagner pads and mediocre luck with the Raybestos (80%+) pads... in comparison to OEM with regards to noise and squeal...
as far as what material - always go back with what stock was... some Lexus' call for semi-metallic pads, some ceramic... I don't believe any use the NAOrganic pads, but there is always that possibility *possibly a hybrid might* I don't have a catalog to look it up, but the info is out there...
One other quick note - usually squeals and squeaks come from improper turning of the rotors or not lubing a slide pin on the caliper causing a pad to glaze quickly... It's more installer error than anything...
Dysfunctional Veteran
Those pads are made in Canada as are most aftermarket brake pads - the exception to the rule would be Duralast and Valucraft being made in China or India, while Raybestos is also sourcing pads from Mexico.
I'll also say Bendix also makes a good pad - except for their SUV line. My neighbor usually takes her car into a brake/tire shop she's used for years and they've always put in Bendix until now. I was able to get them easily locally too - the beater van loved the MKD576 semi-mets.
Really? Ill have to check into that, cause they always advertise how their stuff is made in America. I always try to buy American made stuff if i can, except for cars. DOnt have alot against american cars, I just prefer Honda and Toyota products.
AC Delco is Raybestos made to spec.
i just use simple oem lexus/toyota pads on my ES, and i used oem toyotas on my camry
no complaints on performance, price, durability, noise, etc
get the oem pads from the vendor here, sewell lexus, as they have good prices.
rrr
08-12-09 06:30 PM
