ATF oem or amsoil
OEM is cheap and good if you feel like changing it often. I'd say every 15k miles. Amsoil if you race alot and put extreme stress on your transmission. I personally run the oem T-IV fluid and flush it every oil change. As for my supra, I run the Amsoil ATF because it sees extreme race conditions.
I have put over 50K on Amsoil ATF and sent a sample to generate a lab report. The wear metal counts, which are indications of wears, and physical properties are much better than Toyota T-IV.
https://www.clublexus.com/forums/rx-...ersal-atf.html
This is no BS, or seat of the pant feeling, 100% scientific data from indepedent owners.
Maintenance Moderator
personally, the most I would ever do would be every second oil change (every 9-10k), do a trans drain and fill... only need to replace 3 qts or so, but it keeps it plenty fresh....
flush it every oil change? I know preventative maintenance is good, but that is overkill my friend...
I just ordered 14 qts of Amsoil so that I could do a full flush on the system. I know I ordered a little more than what is necessary because I couldn't get a straight answer on how much was needed for a 2003 GS 300. I read 12, 12.5, and 13 quarts from varying people. Does anyone actually know how much?
quick question, had my gs400 for about 10k miles, previous owner seem to have it up to date with maintenance(but not sure). I'm planing on drain and refill the transmision but am not sure of the brand of ATF previous owner used before. Question is should i go ahead and drain the pan and refill with the brand i want to use(Amsoil)? or do a full flush? (also in a budget with no job) sry for the noob question.
Thanks for any suggestions.
umbro7267
32
02-21-12 12:25 PM
