Magnetic Drain plug (oil)
It won't hurt, but it won't do anything either, so it's your money down the drain even if it's just $10.
Is your engine really putting ferrous metal particles into your oil? as stated above, then you got bigger problems to think about.
Your filter should pick up anything that isn't suspended that would drained out in the oil change anyway.
the main purpose of a mag drain plug is to tell you if you about the wear amount inside your engine. its not really there to filter metal out of the motor. just as the same purpose as the aircraft that i work on at the military.
