30K service...
I should get my car back soon, supposedly, but that a whole different thread. Anyway, what do they do exactly, is it worth it, my car I recall is around 31,000 miles, should I wait?
All fluids flushed (oil,coolant,transmission,differential(s)
Wiper inserts replaced.
Oil and air filters replaced.
Tire rotation.
Inspect underneath (tires,suspension,brakes).
Tire rotation.
Lexustech,
The mechanic at an independent shop told me i didn't need to change my 94 sc400 trans fluid for 30k service. Is it correct? Now at 50k, i checked my trans fluid (with the dip stick under the hood) and it's level was way above the level.
Thx
Thx
How did you check the trans fluid level? Engine hot? Run it through the gears before checking dip stick? On level ground? If not, try it again and see where the level is.
check out this post about how to check transmission fluid
https://www.clublexus.com/vb/showthr...fluid#post9887
Hope it helps.
Hope it helps.
CLUM
01-27-15 06:47 PM
