"Please Help" SC400 Problems Starting
Old 05-15-09 | 11:08 PM
NSeagle78's Avatar
NSeagle78
Default "Please Help" SC400 Problems Starting
Once a week I have trouble starting my SC. I will attempt to start it at least 5 to 10 times before it starts. Pumping with the gas pedal, when starting, does not help any. I do not know if I need a tune up or not. It may leave me stranded one day. Please help.
Old 05-18-09 | 12:07 AM
NSeagle78's Avatar
NSeagle78
Default 1st try
I may have fixed the problem, I use the water hose to run water over all the hoses under the hood. The hose that runs into the front of the engine at the highest point was sucking in water. I replaced the hose.
Old 05-18-09 | 11:53 PM
RTIS250's Avatar
RTIS250
Yes. I drove the LFA.
CL Folding 500000
So you had a vaccuum leak? I wouldnt recommend using water to find the leak in the future.. you can use a small propane bottle with a hose and move it around all the hoses til you find the leak (when the engine idles up).
Old 05-19-09 | 08:44 PM
NSeagle78's Avatar
NSeagle78
Default Reply again please
UPDATE:My car is a SC400, 1992. I was going to take my car to the shop in the morning, but since it will not start I decided to use the paper clip and run codes. Code 31 and 32 came up (air flow meter signal). Do I need to replace that little black box that is held down by 4 phillips screws near the air filter? My car symptoms were that over months it would take 4 to 5 attempts to start. This would happen maybe 1 out of every 10 times I tried to start it and it got progressily worst. I now find myself in this situation where it now will not start. I am not over machanically inclined so answer me like you are talking to a 10 year old.
Old 05-23-09 | 07:44 AM
NSeagle78's Avatar
NSeagle78
Default MAF was bad
Thanks to SC51, Enigma8246, SC-driver RTIS250, and GEORGE JET you guys were a great help. My MAF appears to be the problem. gerri (spelling probably incorrect) came down from Atlanta and sold me a MAF for $50. Since part of my trouble shooting was Plugs, wires and distributor my car sounds great. Again thanks for breaking it down to a 10 year old level. I am totally not machanically inclined. I hope it holds up. Again thanks guys.
DREED2017
05-01-17 12:59 PM
Clear
Performance & Maintenance
08-15-16 06:11 PM
bryanc182
Maintenance
10-06-11 07:25 PM
dcz
10-16-07 07:07 AM
Quick Reply: "Please Help" SC400 Problems Starting
