Brake Cleaner
Brake Cleaner
what's the difference(pros/cons) of Chlorinated vs Non-Chlorinated brake cleaners? I'm gonna do the front brakes so I just wanted to know which is better. I heard chlorinated is bad on plastics. I was also gonna use the brake cleaner to prep/clean the weather stripping that I need to glue back on.
Yeah just realized how bad it is on rubber. I was cleaning the front shims on an RX350 while changing the brake pads and there is some rubber coating on the inside of the shims that bubbled up a bit after being soaked in the brake cleaner. It's not that bad though since it's just added protection against squealing and I used grease for that.
2v1g
12-02-16 06:40 AM
bad, brake, break, chlorinated, cleaner, coating, cons, difference, forum, nonchlorinated, pros, rubber, shims, versus, whats
