Problems after starter replacement on my GS400
Had the starter replaced on my GS400 this week by a local mechanic.After getting home I noticed the CEL was on,the VSC and VSC Off indicators are on(hitting the VSC switch does nothing) and the engine now vibrates..With the hood up I can see the engine vibrating where as before it never moved.It also doesnt have the snap acceleration like it usually does.When idling,it seems to be sputtering.Im thinking off hand the new gaskets aren seated properly.Ill be taking it back to the shop tomorrow but was wondering if anyone has any ideas of what went wrong.Thanx in advance.
P0300 and 303 is misfire on cylinder #3,but I don't know from the top of my head about the P1310. He may left the #3 injector unplug. If you open the hood #3 is located on the driver side not too far from the oil filler cap very easy to get to, just look for the blue connector(injector).
BTW..P1310 Igniter Circuit - No. 2.
UPDATE..Checked that plug(it was loose) and all is good now..The rough idle is gone ,power is back but the CEL,VSC and VSC OFF lights are still on..Is there a reset or will it correct itself in time..Thanx again
