15K Service - Transmission change necessary?
Hi!
I have an RX300 and a GS300 that both need 15K service. The dealer wants $360 per car. WTF???? Is that normal?
The RX I did the dealer thing since they were gonna replace all my brakes and do a creaking sound on the Sunroof but My GS is pretty clean so I just took it somewhere else to get an oil change.
Anything else I'm missing out on? I checked what they did for the RX and 50% was checking stuff (battery terminal, exhaust) and only 30% actual work I need (oil change, transmisison fluid change) and 20% work I didnt' need (rotate and balance tires (can't rotate my directional different offsetted wheels).
So, this leaves me with engine coolant and transmission fluid change. Are these Absolutely necessary?
Please help
Thanks
Please help
Thanks
absoutly NOT. at 15k miles you dont need a gad damm thing done to your car except a oil change, and you can do that yourself, or buy your own mobil one synthetic oil, and take the car to jiffy lube. if something does go wrong with your car,its still under warrenty, if you pay them $360 to check stuff and they find something wrong, it's fixed under warrenty, so tell me what is the reason to pay them $360.
clive.
clive.
clive.
clive.
Well its up to you if you want to change the fluid but if it was me I would seening that $ 50,000 is a lot of money to just neglect.
Its going to take about 2 1/2 gals. of Type T IV fluid for the change. Oh yeah, it runs about $ 30.00 a gal.
Aloha
Longo's 15K is $215. Not sure if that includes trans. fluid flush and refill though, as this is the first time i've heard of a Lexus needing a trans. fluid change so soon.
the 15K for an '02 ES is basically just an oil change, A/C filter change if necessary, and tire rotation. Which should run me $30 total if I'm not feeling too lazy to do the oil change myself.
I guess I could pay Lexus another $200 for them to glance around the car and tell me everything's okay, but they'll do that for me anyways during just an oil change. After all, if they find something wrong, it only means more $$$$ for them.
IG - They didn't need to remove the tranny filter so that's probably why U didn't see it. It's just a simple mesh element that U can clean yourself if ya drop the pan ( although that's not necessary just to drain/refill the tranny as the GS has a drain plug ). In fact, that's all they do for the required service because they believe that if U need to change or replace the filter because of blockage then U have more serious problems within the transmission! :eek: ). Still, I change my fluid at 15k intervals & drop the pan at 30k just to be cautious; after all, the T/C does generate extra heat, even with the auxillary cooler I added ). And before we jump off into the next "usual" question, I think that the Lexus ATF fluid is fine as does Mo - besides, I don't think anyone has a synthetic ATF for the Toyota/Lexus marquee unless Ron found out some more from Redline?
NV - The factory long life coolant is designed to last 100k but I'd still change it more frequently ( at least at 50k but I'm Type A & change at 30K ). I know that it's probably NOT necessary to shorten the drain intervals that much but I'm still old school & agree with It's about protecting a $50k+ car.
Wow I didn't know that dealers could be so far off. My dealer is Jim Falk of Bev Hills (okie okie, they sound expensive already) but well, I figured all dealers had some sort of guideline on pricing and won't stray too far away..But man, $215 and $360 is a BIIIIG difference.
