ABS help
have a 90 LS400 w/trac.
The rear speed sensor was bad so replaced it. But the code 35 doesn't seem to go away. The abs/trac off light is on. Did the whole clearing codes routine but it stays. Changed to front left sensor as well as the rear right sensor as that's what code 35 means. no change.
Wanted to know what else I could look into ?
thanks.
thanks.
did u try to clear the code? or go for a short test drive??
ABS & TRAC codes are cleared by keeping the jumper wire in Tc and E1 and then pressing the brake pedal 8 or more times within 3 seconds, good luck
scbuddy
06-08-09 05:17 PM
