Oil leak!!
Oil leak!!
as i was leaving my friends house this morning, i found a decent sized wet spot under my car. i rubbed my finger in it and it was oil. I have never had to deal with a problem like this so how should i go about solving it? also about how much will it be to fix?i checked the dipstick and the oil mark was just above the second dot. help please
Yes. I drove the LFA.
Kind of hard to tell you how much its going to cost to fix if we have no idea where the leak is coming from. It could be as simple as a cracked drain plug gasket or a big as a rear main seal leak or worse. There is no way to estimate a repair cost without knowing where the leak is coming from.
