oil filter for 1jzgte???
hey guys i had a question i have a 1jzgte.. does it use the same oil filter as the usdm 2jzgte from the supra??? which one am i suppose to use?
thx bro!!! while im the subject of 1jz.. do u know if the power steering pump for the 2jzgte will fit on the 1jzgte.. mine is so messed up.. and i really haven't foudn much info on what to do to replace it.. i can't even rebuild the one i have
The 2jzgte power steering pump does work, but the mounting holes are different.
You have 3 holes in the pump, but depending on what motor the holes you use are different and 1 will be slightly more narrow for some reason.
I had to drill out the 2jzgte hole to fit the 1jz mount bracket.
ptetra
CT 200h Model (2011-2017)
13
10-02-22 06:59 AM
