wiring a swap
Sounds like you need to do more research.
What kind of 2jzgte, out of what car? You should think about replacing all the seals,water pump timing belt, thermostat all while the motor is out, because it is alot easier to do then.
Wiring? I recommend Dr Tweak at Phoenix Tuning. He knows toyota/lexus wiring
For about the same price after motor,maintenance and wiring you could've installed single turbo kit on your existing motor, depending on what condition it is in.
Lots of options, lots of variables..that's why the research is so important. Try to cover all the bases before you buy that motor really..30 day startup warranty...
Ryan
Ryan
