1999 RX300, 1315 Diagnostic Code
I have a check engine light on. I ran a diagnostic and got code 1315. I cleared the code and was fine for a week. Same thing happened today. Any ideas?
P1315
Igniter Circuit Malfunction (No. 4)
http://www.obd-codes.com/trouble_codes/lexus/
p.s.: Have no clue what that means.
Yes. I drove the LFA.
You likely have a bad #4 ignition coil... The igniter is built into the coil, it is a fairly common problem on the ES and RX for the coils to fail over time. It is also possible to have wiring damage due to rodents, so id take a peak at your wiring. The #4 coil is on the front bank, its the middle coil. Try swapping the middle (#4 coil) and passeger side (your left and #2 coil). If the code follows the coil, and you get a P1305 code, then you have a bad coil.
sktn77a
RX - 1st Gen (1999-2003)
10-25-15 12:46 PM
1996, 1999, 99, circuit, codes, diagnostic, diagnostics, gs400, igniter, lexus, ls400, maintenance, p1305, p1315, rx300
