Stuck brake caliper SC-300
Before I take my SC-300 (97 5 speed) in for repair:
What are the first try fixes for a stuck front brake caliper. The sticking is not always severe (pulsing) but should be fixed. The car will go in Tuesday (by flatbed) if nothing shows up here.
Thanks.
**** Barber
Thanks.
**** Barber
You sure it's a sticking caliper and not warped rotors?
Warped rotors can be characterized by pulsing or shuddering under heavier braking loads...
You can use some high-temp grease/lubricant to help free up the calipers, thus saving $$$ from taking it to the $tealer (I mean dealer).
Hope that helps.
Hope that helps.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
