AC Filter????
Originally posted by khark
Does anyone know the exact dimensions of the A/C filter for a '95 SC400? I checked for mine and there was no filter element in it so I can't measure it to cut a new one from a furnace filter.
If so, just measure the plastic trim/housing piece the filter slips into and your good to go.
I think your better off just finding the best price for a factory ac filter.
DD
I agree, the filter for the SC is an oddball, so I bought one from Carson. I will probably change it once a year, and may look at saving the plastic frames from the two filter elements and cutting and fitting 3M filter medium to fit, a few dabs of hot glue, see how it does.
My '93 didn't have a filter, and judging from the amount of guck that fell out in my face when I opened the little door, I doubt if it ever had one, even though the a/c unit has the slot, etc. The "D. Opt." is Dealer Option - when the car is bought new the buyer can have the filter installed, it's a profit center for the dealer, just like the oem cell phones, which are all instelled locally too.
Like DevilDog says, this is a tricky filter and getting it in right the first time you try it is tough. The filter is made by Denso and comes with an instruction sheet which takes a little noodling. Take your time and be sure the door fits just right before you put the wingnuts back on.
take the filter out, shake it to get all the dust out, rise it several time with water, putt alittle of hand soap if you like.
basicly just rise it with low pressure water. Let it air dry.
See how to built the new filter from cheap hepta air filter at home depot on my webpage.
I replaced mine on my gs for 30 bucks, bought it from Kragen Auto parts. Next time I will try washing it. Does anyone know where the filter is located on a 2000 ES300, I open the glove but it isn't the same at the GS, do I have to take the glove off. Is the filter the same for all cars? Thanks
Here's a thread from the RX forum regarding the cleaning of an OEM filter.
https://www.clublexus.com/forums/sho...threadid=59500
How to do edges?
I bought a 3M Filtrete (http://www.3m.com/us/home_leisure/fi...11_ultra.jhtml) for $15 (10"X25"). I cut it approx to the same size as my RX filter. The OEM filter has a plastic edge that fits into the clips and ensures a snug fit. How do I do the same with my 3M filters?
