AC Filter????
AC Filter????
How hard is it to replace the AC filter by yourself? I need to replace mine....can anyone give me some pointers on how to do it? Is it hard? Is it easy?
Any help would be much appreciated!!!!
A/C filter
Open the glovebox
The top panel of the back of the glovebox is removeable, remove it.
With a flashlight you'll now be able to see the plastic door covering the filter, the door has an "UP" arrow on one side indicating which way it goes back. Remove the door.
Slide the filter tray out of the A/C plenum.
Note: the centrifical blower is just below and the inlet air duct and the recirculate mixing vane/flap is just above.
You can buy a replacement filter at Lexus for about $50 or you can go to home depot and buy the largest top-of-the-line furnace filter (3M filtrete) for about $15 and take it apart and use a pair of scissors to make three Lexus replacement A/C filters.
Jobs
Go to home depot and read the label on a 3M "filtrete"(sp?) furnace filter. I personally suspect it will be a betetr overall filter than the one Lexus sells.
Becuase of some design flaws (by Denso) in the Lexus climate control system Lexus' owners in the southern states suffer from a horrid musty mold odor and those of us in the northern states must live with incidents of sudden windshield fogging.
In a climate wherein the average overnight ambient is above 55F the thousands of square inches of damp and dark surface of the A/C evaporator within A/C plenum provides an excellent breeding ground for all types of mold and mildew. It's likely that the primary design purpose of the A/C filter is to deprive them of airborne food for growth.
How do you go about making your own filter? Once you cut out the filter piece you need, do you have to attach it to the frame of the old A/C filter?
I probably should take a look at the A/C filter first to see what it looks like...
replacement
I'm not so sure using a fixed time period is really appropreate.
The A/C air filter will become clogged sooner or later depending as much, or more, on "atmospheric" conditions (dusty roads, springtime pollen) as on time. Wouldn't hurt to check it more often, it's a really simple and easy DIY task.
Thanks for the replies.
I checked my A/C filter yesterday and it looks ok. I try to clean it a little bit and I wonder can I wash it and keep using it!? Anyway I'll try to DIY my filter like you guys did.
is there a a/c filter for the 1st gen GS?
My repair manual shows one but it says 'D Opt' next to it. I can only imagine it stands for Dealer Option. Any ideas? There aren't any detailed instructions or any direct reference to the a/c filter.
I doubt it but you can try this.
I don't think there is... but if there is it would be located right behind your glove box. Open your glove box and look to see if there is a removeable black piece in the rear to get to the A.C. filter. If there is remove it and see if there is anything behind it. If not then you don't have one! Hope that helped.
Re: A/C filter
Originally posted by wwest
Open the glovebox
Open the glovebox
Thanks
