Helpp guys DTC 13
rpm over 1000 is the code and yet the rpm is at a normal 600ish
replaced both cam shaft position sensors
replaced crank shaft position sensor
replaced sparkplugs
replaced the sparkplug wires
new distributor cap and rotors 40k agao along with timing belt
checked timiming belt and it is lined up correctly
what else would cause this problem?
replaced sparkplugs
