seat issue help!!!!!
i just got my 95 sc300 sweet blk on blk car over the weekend and the power drivers seat is not operating properly . The seat is all the way back and when you try to move it up only one side of the seat moves like crooked and im afrraid to keep dooing it as it might break completely thanks any help would be greatly appreciated
too k the seat out of the car major hassle since it was all the way back it looks like there is several motors that control different things they seem to be operating fopr everything but the track on the right side of seat will not move is there a way to disable it to get the seat position foward or a way to check why its doing this please help
you can turn it manually - basically the motors turn the big long screw looking pieces - its been a long time since I messed with them, but I believe the motor is probably still working, but it isn't engaging the screw because of something broken - I was able to fix mine once but it didn't last long... either way, you can manually move those screws by using a (10 or 12mm) socket wrench with an extension - you can actually do this while the seat is in the car as well, so, its a poor mans adjustable seat....
