1997 lexus es300 O2 sensor Replacement fault code po 136 bank 1 sensor 2 replacement?
97 lexus es 300 O2 Replacement fault code po 136 bank 1 sensor 2 replacement?
I just tried to replace the sensor that is right by the CAT. The connector wire was long and I noticed the connector must be under the floor? in the body of the car? It seemed like a longer than normal wire. Anybody know how to get to that clip? I can change the sensor but reaching that clip seems a bit far. also does anyone know the toyota part # for that sensor?
thank you greatly appreciated![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
was thinking I had to dissassemble console
here is also a link for sensor if anyone else needs one I got pretty cheap
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
can someone be more specific to pinpoint location or procedure. I was also told connector is near hump in console. trying to job as painless as possible. through console or sneak under carpet through 2 cut holes in carpet under passenger seat maybe? or remove passenger seat completely and lift carpet. thanks for your input in advance.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
FYI just to let you know .. The location of the connector clip on a 97 ES-300 is under drivers seat . After removing Console and driver seat I ended up accessing it through the 2 holes in the carpet under the drivers seat which can be done by simply sliding the seat all the way back . My sensor started to strip so I heated with a torch and removed with a pipe wrench. Was pretty easy job but could of been a lot simpler . hope this helps someone
gvse
05-07-14 06:48 AM
SICK350
ES - 5th Gen (2007-2012)
03-11-14 05:20 PM
