Lexus Service Scam/rip-off in Southeast Florida
Old 02-09-11, 08:34 PM
jeffmiami1
jeffmiami1's Avatar
Unhappy Lexus Service Scam/rip-off in Southeast Florida
I recently took my GX470 to a local Lexus dealer for routine oil maintenance and to check the battery - as I suspected it was going bad. While waiting, the service rep comes back to me and says I needed a throttle body service (for improved performance and gas mileage), power steering flush (discolored), new wiper blades (dry rot), and new cabin and engine air filters (filthy).
"I just had a 60K service, 7k miles ago, weren't any of these items covered?" "Of course not," he responds. I usually know better, so I decline everything but the PS fluid flush and the wiper blades.
I get home, pull the old invoice on the 60k service, and see that my wiper inserts, air filters, and throttle body was indeed serviced at that time. I also pull both filters from the car and they're practically new.
I'm going to complain to the Service Manager in the A.M.
Old 02-10-11, 08:45 AM
dugw
dugw's Avatar
with my past experiences with dealers, i trust them as far as i can throw them.
Old 02-10-11, 09:51 AM
BDSL
BDSL's Avatar
Well, with my past experiences with dealers and specialized shops, once in a while they make mistakes. I always check their work.
Old 02-10-11, 05:58 PM
svlexus
svlexus's Avatar
That sounds like a scam if they are doing the same stuff from one service to the next. Id tell them they gonna get reported to BBB and see what they do for you. And then report them to the BBB.
Old 02-11-11, 12:01 AM
Hayk
Hayk's Avatar
Aren't all dealers like this? They will always try to take advantage of you.
Old 02-11-11, 05:55 AM
Invalid321
Invalid321's Avatar
Every shop will try to upsell. Its not just dealers, but they get the bad name. Sounds like that service manager is a clown, and quite possibly the entire service department. Try a new place!
Old 02-12-11, 05:30 PM
KillaIS250
KillaIS250's Avatar
dealership = Stealership.
They will try and get you for every nickle and dime they can. Just got to be careful like you did, and make sure services your paying for are services you actually need.
Old 02-24-11, 06:13 AM
305Busa
305Busa's Avatar
JeffMiami, Im in Miami as well. (Im assuming you are also). If I may ask, which dealer was it. You dont have to give a name, maybe just a vacinity. Thanks.
Old 02-24-11, 01:42 PM
TCM55
TCM55's Avatar
What is the update on this story?
Old 02-28-11, 06:04 AM
jeffmiami1
jeffmiami1's Avatar
TCM55-
The battery died 3 days later (as I suspected t would), and the service department replaced it. The manager I spoke with apologized and assured me this was an isolated incident. If they were smart, they would have done more for me (refunded my money for the prior service) since I had to take time out of my schedule again; I won't hold my breath for a letter in the mail.
Next time, I'm tagging the filters...
Old 04-13-11, 07:41 PM
ironoxide1
ironoxide1's Avatar
Originally Posted by jeffmiami1
TCM55-
I work in service at a Lexus dealership...In general...we never recommend something if its not needed...nor do we not do something that a customer has paid for...in our shop...about 4 years ago...our service manager fired a master tech for un-ethical practices...that pretty much set the tone of how things are gonna be in our shop...as a service consultant...it is my job to present you with the findings of the tech...I have no problem telling you or anybody else...that the tech IS looking for something to upsell...hes not making it up...but he is hoping he finds something that the customer will want done...keep in mind...it is your choice as the customer on what repairs you want done...this is your car...I would be doing you an injustice if i didnt tell you...and on the other hand...when I tell my customers that there car is in great shape...they know as well as I know that the tech has thouroughly inspected thier car...and for that...I will hold my head up high...proud to work at a Lexus dealership
Old 04-13-11, 09:42 PM
xsh0tya
xsh0tya's Avatar
So in short you would report them. I have no problem with that but why even bother talking to them if the end result no matter what is going to report them? If I was running a business and a customer complained and I went out of my way to fix it and I did and they still reported me, next customer is getting a nice "F-word you". In closing some actions cause problems for those down the road. Please dont litter.
Old 04-14-11, 05:41 PM
gemigniani
gemigniani's Avatar
Sounds good, but the upselling can sometimes get out of hand. Like the last time I took my '91 LS400 in for a timing belt job, the service writer said the tech noticed that one of the rear axle boots was torn and and had leaked 1/4 of it's grease and would cost alot of $$$ to replace. I later got under the car and carefully checked the boots myself and found nothing torn or leaking. Then they also tried to sell me a whole new PS pump and PS hoses due to a small seepage leak, but I fixed the leak myself by installing a new reservoir O-ring and I cleaned the partially clogged steering rack solenoid filter screen to reduce hydraulic pressures in the system that tended to aggravate leaks.
Old 04-16-11, 08:41 PM
Spooled
Spooled's Avatar
Not saying either party is right or wrong here, but in the shops defense did your 60k invoice say "adjust throttle cable linkage" or anything like that? Some of our 30k, 60k, 90k services are programmed to say the same thing in every repair order. So even a car that has no throttle cable, will have "adjust throttle cable" in the repair order. The service the technician may have been reccommending may have been different then what was included in your 60k service.
Old 05-04-11, 09:11 PM
johnnyg66
johnnyg66's Avatar
I called my local dealer to ask about having them check the AC and was told they don't service older models there unless you bought it from to start. Is this common??
Quick Reply: Lexus Service Scam/rip-off in Southeast Florida
