Noise When backing and then applying the brakes
When I go in reverse and apply the brakes i hear a noise, it sounds like it is coming from the front of the vehicle. The car is a 2002 SC430 with 77600 miles.
Chances are it has always been there, just maybe not as audible... Its just the brake pad moving inside the caliper from the front to the rear - there is a little play in there, which is perfectly normal...
Sometimes, the little spring clips wear out and make the click a little louder...
I would take a look, or have someone take a look to be on the safe side, but, I would bet its something you probably never have to worry about...
Baptizer
09-03-14 12:21 PM
