Wheel Alingment '10 IS 350
I had new Conti Ext DWS installed, along with 4 wheel alignment. Car has slight pull to the right, went back to independent shop that performed 1st alignment and they made corrections again. It still pulls slightly to the right. What is the experience of others, should I be able to expect a neutral steer going down a flat road?
Below are the recent results after correction;
FRONT LEFT RIGHT
Caster 7.5 7.5
Camber -0.7 -0.6
Toe 0.05 0.05
Total Toe 0.10
REAR
Camber -1.3 -0.9
Toe 0.20 0.20
Thrust Angle 0.0
FRONT LEFT RIGHT
Caster 7.5 7.5
Camber -0.7 -0.6
Toe 0.05 0.05
Total Toe 0.10
REAR
Camber -1.3 -0.9
Toe 0.20 0.20
Thrust Angle 0.0
Dysfunctional Veteran
I would say your camber angles might be to blame. They should be even unless you are only ever turning one direction at very high speed (I.E. Nascar) LOL.
Probably tire pulls. You can ask them to cross the front tires, even if the tires are directional it won't hurt to drive them only for a few miles.
You can not adjust the camber on the IS or most of Lexus cars. The camber stay in the negative side which is good because you only have camber pulls when your car have the + camber.
I am sorry, i thought I read in there somewhere you had suspension work, it must have been another thread I was reading in a different tab.
No the camber is not adjustable, which means VVT-i is likely correct. Have them cross the front tires and see if the pull changes to the other side.
I agree that it is most likely a tire issue... definitely rotate the fronts side to side and see if the pull changes...
Who is doing the work for you? If the alignment and tires are done at the same shop, then I would hand them the keys and say fix it, it was fine before. If you were standing in my shop with this issue, I would have already replaced the front two tires at minimum as a diagnostic tool...
If they were done at different shops, you may get the blame game where each shop blames the other, though still, with a printout of alignment settings, and an ever present pull, the tire shop should still replace the front two tires. They don't get charged anything - they can send the tires back for 100% credit, so don't feel bad... They also may replace just one at a time, but whatever it takes...
I'm not a huge fan of the Conti's - personally, I'd swap to a better tire in general...
