08 ISF Dash lights are going crazy
so yesterday at night i take the isf for a boot, everything is going great and then i rip it off the lights, as soon as i do the traction starts acting weird and so do the rpms for a few seconds, rights after that the light show started.
check vsc, abs off, traction control off, afs off. all came on at once. i didn't turn anything off.
anyone experience this before?
Sounds like you have a speed sensor or something acting up... lots of other things it can be as well, fault in the electronic throttle body, abs pump not responding properly, who knows...
get it to the dealer (under warranty hopefully still) and have them check it out... if its not under warranty, need to find a way to pull the codes - most cheap code readers probably won't get the job done, need a real scanner more than likely...
the car is completely stock. i have a feeling the sensors are just acting up. i made an appointment with my local lexus dealer butt hey ant $120 to diagnose it so im checking if anyone here can help to save the money.
Dysfunctional Veteran
Book at a different dealer. You should still be under warranty. There should be NO diagnostic charge.
