90 lexus ls400 axle popping out
the passenger side axle keeps popping out and i think if its like a hondas axles they have a loose ring or retaining clip on the end. if so than thats what im missing, then that brings up the question did i damaged my diff. when i pop it back in it drives like nothings wrong so that leads me towards the retaining clip.
any help would be good help and thank you.
mr.carr
mr.carr
Dysfunctional Veteran
is there any way you could post a photo of what you are referring to?
At 200k I would say its probably time to replace the axles. They could be worn beyond spec.
the snap ring is nonexistent on that side as for the suspension there is zero play.
it did not completely pop out of the diff but however it was enough so realize these cars dont come with an lsd and it lightly worn the end of the shaft but not enough to where a snap ring can not be replace.
pics will be added soon.
tyncobb
03-18-16 12:33 PM
