Replacing Timing Belt AND Water Pump?
Old 10-30-12, 05:01 PM
konaboi808
konaboi808's Avatar
I would say change them both. I had a car come in and the fins were corroded. Causing the car to overheat. Coolant in the oil. The cost of repairs is more then the first minor cost when compaired. Also 2 years is alot of time for something to happen. Good luck finding a good shop.
Old 11-27-18, 11:37 AM
GTright
GTright's Avatar
Originally Posted by BDSL
You can attach a long breaker bar to the crank bolt, then blip the starter.
I have done this many times.
Just make sure your engine turns the right way or you will break/strip the bolt.
can any thing else get broken doing this? I have 1993 sc400 I did this and after I took out my plugs and found TDs I then was going around again 2 times to be sure but 10 percent into the rotation I ran into something 80 percent in the opposite direction and the same thing an not get a full rotation please help me understand what I could be hitting thx .
Old 05-01-19, 06:38 PM
jordysays
jordysays's Avatar
what pump to with for an IS 250 year 2009 ?
RX4UNME
RX - 3rd Gen (2010-2015)
10-31-18 01:02 PM
GibbsLexus
08-09-17 07:18 AM
Harvey99
05-30-15 08:04 AM
iman61701
10-26-10 03:42 PM
Quick Reply: Replacing Timing Belt AND Water Pump?
