Messed up exhaust stud removal?
Old 03-10-12, 06:25 PM
Shiryo
Shiryo's Avatar
Default Messed up exhaust stud removal?
Just wondering what I can do to remove these three studs, going to replace them with some better stainless steel bolts and nuts from my local Ace Hardware store...
1 is snapped and all three have bad threads.
Was thinking of picking up the stud removal tool from Harbor Freight but not sure how it's going to turn out. I have the studs soaking in Aero-Kroil for the time being...
http://www.harborfreight.com/1-2-hal...tor-94640.html
Old 03-10-12, 06:47 PM
ArmyofOne
Dysfunctional Veteran
ArmyofOne's Avatar
yes, either drill em, grind/cut them flush to extract them or use a stud remover.
Old 03-10-12, 06:55 PM
Shiryo
Shiryo's Avatar
I'm skeptical on the drilling or cutting... Do you think that removal tool from Harbor Freight will work?
Old 03-11-12, 07:39 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
when they are as rusted as yours, you might not have a choice... reality is that it took a lot of twisting to break that stud and if you twisted enough to break a stud but the stud didn't come out, it probably isn't going to come out no matter what you do...
do as Army says - cut the stud off flush, drill it... unless you want, you don't even need to tap it, just put a bolt in from the back... might be a little more difficult to tighten, but still easier than rethreading...
JorgeNery
02-27-17 08:54 AM
sj408
Performance & Maintenance
15
10-26-15 10:57 AM
jstyles129
Suspension and Brakes
07-17-09 06:33 AM
djspawn00
Performance
11-09-08 12:16 PM
Hil
05-29-07 04:25 PM
Quick Reply: Messed up exhaust stud removal?
