Turn Signals on GX 460
Old 04-04-12, 03:47 AM
Capirato
Capirato's Avatar
Default Turn Signals on GX 460
I need help in locating a wiring diagram for the GX 460 to accomplish the following.
(The wire must be connected to a point that is at ground voltage when the turn signal is ON. You must find a point that is ground when the turn signals are ON to make the unit work.)
~ Cap
Old 04-05-12, 05:48 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
What are you trying to accomplish?
I can't look until tomorrow, but if the GX is like almost every other vehicle out there, the lamps ground to the chassis, so, following the quote above, any ground in the vehicle will work, including the chassis... AFAIK, there is no wire that is ~only~ grounded when the turn signals are on, so hopefully that isn't what it is looking for...
Old 04-15-12, 03:25 PM
Capirato
Capirato's Avatar
Cody.....
I may have to use a relay to get a ground. I just have to find a solid positive from the Turn Signal switch, to operate the module when either right or left blinker is on.
~ Cap
Capirato
03-27-14 07:44 AM
GreggyG
GX - 1st Gen (2003-2009)
11-11-13 11:41 AM
Capirato
GX - 2nd Gen (2010-2023)
18
04-16-12 12:13 PM
geewiss
07-30-04 10:52 PM
Quick Reply: Turn Signals on GX 460
