new with IS300
Hi
I’m new to this forum
i just got my 2005 is300![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
but i have some issues with the car
1- oil level indicator is on even when i changed the oil . . . what would be the problem?
2- traction indicator is blinking !!!
3- check engine is on
4- the A\C is cold on the driver side but it is hot for the passenger side
5- where to find the horn and high beam fuses ???
thanks a lot
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
thanks a lot
Hi
thanks a lot
thanks a lot
Traction indicator blinking - hard to say, could be a wheel speed sensor, computer issue or other - will need a scan tool (a good one) to find out for sure...
check engine - at least get to a place like autozone that will pull codes for you and report back...
a/c - you have a blend door issue - the door is stuck, broken, or the actuator does not work. this can be a pain to fix properly...
there are two fuse boxes in the car, one under the hood, one to the left of your foot if you were driving... to the left of the brake pedal...
