Please Help with spark plugs
Hello CL members!
Just a simple from a noob.. I have a GS400 with 143k miles, I wanna replace the spark plugs I just wanna know is it necessary to replace the spark plug wires as well?
Any help is greatly appreciated
What year, and are you sure yours has wires at all? I can't recall, but at some point, the V8's went to coil on plug instead of using distributors... With the mileage on the car, if it has distributors, I would say its recommended at the same time to do the cap and rotors...
If you have plug wires, you can check to see if they are good or not by checking their resistance..but I'm not 100% sure what spec is supposed to be. I was always told 12-15k ohms per foot? don't quote me on that though!
If you are going to replace them, I would recommend against the brand called Valuecraft carried by autozone.
Toyota/Lexus (should be Denso), Bosch, and even Duralast (another AZ brand, but better) are all acceptable.
[QUOTE=ArmyofOne;7162511]If you are going to replace them, I would recommend against the brand called Valuecraft carried by autozone.
Toyota/Lexus (should be Denso), Bosch, and even Duralast (another AZ brand, but better) are all acceptable.[/QUOTE
Armyofone thanks for the input.. I was looking online thinking about getting the Denso, NGk or TorqueMaster ones cuz a lot of members are using these brands
[quote=GS4TEK;7164198]
Denso and NGK are the OE plugs... Iridium if you want 100k miles on them, Double tipped platinum should get you 60k and copper, 15-30k...
