SC300 fan clutch
SC300 fan clutch
So, I bought a new fan clutch from a well known CL dealership and got an extremely good price. But I'm pretty sure it is defective :\. When the car is on it is free spinning even at operating temperature. No matter the load placed on the engine it spins freely I can literally stick my hand down there and stop it. Pulled it off and tested it with a heat gun on the coil spring thing and it didn't react at all. Is it defective? I'm 99.9 percent sure it is supposed to get tighter with heat..and it doesn't. I also know that fan clutches are filled with fluid but it is a sealed unit. Anyone else have a similar issue?
here is a proper guide of how to test... http://www.autozone.com/autozone/rep...uctInformation
is the car overheating? if not, chances are it is ok...
It should be spinning much faster if the vehicle is getting that hot...
Also, it is perfectly acceptable for a car to be at operating temperature and it not be fully "locked" up spinning 1:1 with the engine - that wastes a lot of energy...
what if you could stop the fan while your cars running?
The fan clutch will not engage until the coolant reaches a certain temperature. Mechanical/hydraulic fan clutches sap a lot of power/fuel economy when engaged all the time, so they only engage when needed.
change, checking, clutch, fan, gun, heat, hiw, install, installation, installing, lexus, replacement, sc300, thermal, tutorial
