K&N Cartridge Filter - RX350 application could it
Could a K&N Cartridge Oil Filter for a RX350 w/ the V6 3.5 L
be used onto a 07 Lexus IS350...
seeing that both use the same motor, could it work with the Lexus IS350 ?
funny I dont see an application for the IS350 w/ the V6 3.5 L motor
but I see an application for Toyota/Lexus models with the identical V6 3.5L motor
any insights? is there an actually difference?
More than likely there is a difference, but you would have to find one side by side to compare... chances are if the filter worked for the other vehicle, they would have it listed on their application guide as well...
GS4 - while I do kinda agree that the K&N may not be worth the money, they aren't as bad as many people make them out to be... You should read this: http://www.knfilters.com/MAF/massair.htm
Thanks for the input but not to be rude but was talking Oil Cartridge filters not the K&N Drop in air filter
and for drop in filters, I use the AfE Pro Dry S drop in fitler...
none the less, yeah I was actually trying to clarify Oil Filters LOL!
