First Oil Change
Old 10-03-12, 05:09 PM
2013rx
2013rx's Avatar
Default First Oil Change
Picking up my new RX-350 this week.
I noticed the first oil change is scheduled at 10k miles. I usually change the oil the first time in a new vehicle around 2500 miles to clean out the metal shavings that will occur when breaking in a new engine.
What are your thoughts ob this, am I old fashion in thinking this way?
Also does anyone know if the new Lexus's come with a full synthetic oil fill from the factory, Is Synthetic recommended?
Old 10-03-12, 05:34 PM
ArmyofOne
Dysfunctional Veteran
ArmyofOne's Avatar
You can use synthetic. I would wait till around 2500 miles and do the first oil change to synthetic, as you suggested. Something about old habits dying hard. I cant stand the thought of pushing even synthetic oil past 6500 or so. I would NEVER go 10k.
Old 10-03-12, 05:58 PM
2013rx
2013rx's Avatar
I'm with you, I'm not going 10k, It means 1 extra oil change a year for me. I'll go 5-6k tops.
Old 10-04-12, 01:28 PM
ZEEE51
ZEEE51's Avatar
Yes the 2010-2013rx comes from the factory with 0-20 synthetic oil. Years ago lexus recommended oil change every 3750 miles then they went to every 5000 miles, now on some models,( soon to be all models), 10,000 miles. One of the problems with 10,000 miles services is, if you miss a oil change service, you might go 20,000 with out an oil change. All to save a little money.
Old 10-04-12, 03:46 PM
2013rx
2013rx's Avatar
I'm pretty **** about oil, oil filters and the frequency of changes. I'll stick to 6-7k on a quality synthetic. Does anyone here change their own oil? I'm assuming there's nothing tricky to the RX oil changes. I hope it has a regular spin on oil filter and not a canister.
Old 10-04-12, 04:59 PM
2013rx
2013rx's Avatar
I just checked it is the cartridge type filter, Does anyone have any experience in changing these, are they easy to get to?
Old 10-05-12, 06:08 AM
BDSL
BDSL's Avatar
Just make sure you don't crack the cap. You have to get the right socket......
Old 10-05-12, 08:59 AM
ZEEE51
ZEEE51's Avatar
With the right socket it is easy to change, just do not overtighten the cap when you install it
Old 10-05-12, 04:51 PM
2013rx
2013rx's Avatar
Is it a special tool needed or a 1/2" socket?
Old 10-07-12, 10:25 AM
sgmbab
sgmbab's Avatar
I would use synthetic right away to help the engine stay as close to factory clean as possible. I've used penzoil platimun for about 4 years now and its great. Good price, great oil, and you can pick it up at any walmart.
Old 10-08-12, 05:09 AM
AaronBradd
AaronBradd's Avatar
I don;t think so.You must contact their service section for more info.
painting fl
Old 10-08-12, 08:08 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
There is a special tool... Assuming it is like every other Toyota now, there is a 1/2" socket hole - that is only used to remove the center piece as a drain...
Something like this is what you need:
Amazon Amazon
Old 10-08-12, 08:51 AM
2013rx
2013rx's Avatar
Thanks Mitsuguy, So that one will fit the 2013 RX-350?
Old 10-08-12, 09:07 AM
mitsuguy
mitsuguy's Avatar
Haven't personally confirmed it, but it works on every other Toyota so far... 64mm with 14 sides... could always measure just to be sure...
Old 10-21-12, 07:26 PM
trtrtr59
trtrtr59's Avatar
Hi 2013RX. I am in same boat you are - a new 2013 RX350 intending to do my own oil changes. I also doubt I will wait 10,000 miles for the first oil change.
I picked up an oil cartridge wrench for Lexus from a company called Assenmacher Specialty Tools, Inc. Here's a link to their oil cartridge socket:http://asttool.com/detail_page.php?f...nge%20Products
I just got mine in the mail and it is such nice quality that I turned around and ordered their Threaded Oil Funnel that fits Lexus and Toyotas with threaded oil caps:
Amazon Amazon
I don't know if the link to Amazon will show up on my post, but the tool is Assenmacher OFTOY1038. Of course, both tools are a little pricey, but so is the car you just bought.
Quick Reply: First Oil Change
