2002 es300 (trouble code problem)p1436
I have a 2002 lexus ES300 , I changed the timing belt, I drove the car for three days. Check engine light came on. I thought I put the timing belt on wrong and did it again.Then the check engine light came on. The trouble code came up P1436. I had a mechanic check on that code and he tells me its a variable timing sensor. I pulled that sensor out and put it back in with out unplugging the battery cable. That check engine light went off. I drove 600 miles. The light came back on and the same code came up again P1436. Should I change that sensor? Also, how can you check if that sensor is bad?
PLEASE HELP
LUIS
PLEASE HELP
LUIS
Remove the banjo bolt where oil supply enters the rocker cover- inside is a little metal filter, more than likely this filter is block with carbon from the oil, if it is blocked you may clean it but also flush the oil system
MemzaEyz
12
12-08-13 01:52 PM
