Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
- Lexus: Why Do My Brakes Squeak?
Guide to diagnose trouble and recommended solutions
Most likely cause of this squeak (brakes on LS460)
Hi guys,
I'm getting ready to tackle a brake squeak issue on my LS460 at the weekend, but as I've always avoided messing with brakes I could use some input from knowledgeable ones on where to start
Basically when parked up if I press my foot hard down on the brakes, I get a muffled squeak (almost like a squeaky windscreen wiper noise) from the front passenger side. I can reproduce it as many times as I like, and the same brake also seems to grab slightly when releasing the brakes as I pull away.
Any ideas?
Any ideas?
First off, If you feel like that passenger front corner is still "grabby" after you let off the brake, I'd immediately say you might have a caliper that is starting to hang up. if this is the case, that corner will get excessively hot during braking ( think of somebody keeping the brake applied 10% of the way the entire time you are driving) . Pads get to hot and become glazed, there's your squeek! Some questions. Does it only squeek when you are pressing the brake pedal down, or does it squeek all the time? When braking, does it feel like that passenger side brake is applying harder, or making the car pull to the right?
1) If I go out to the car now (even though its not been used all week), start the car and plant my foot hard down on the brake pedal (with the car still in park) I will get this squeak from the passenger wheel area. I can keep pressing the pedal hard and making it squeak as many times as I like.
2) If I then go to pull away by putting my foot on the brake and switching the gear lever to D, when the gear engages and the car tries to pull forward I'll get another squeak.
3) When driving if I brake (hard or soft), the car brakes in a straight line without any squeak.
4) If I stop at the lights, when they turn green and I take my foot off the brake I get a tiny squeak accompanied by what feels like the pad grabbing slightly on the passenger side.
Hope that helps?
I would not recommend novices do any work on their LS460 brake systems. They are electronically controlled, and cant even be bled properly without a scantool. The LS460 is known to have a "chirp" type noise come from the abs actuator assembly when applying the brakes, even when at a stop. The initial remedy to this is to do a full brake bleed. If this doesnt solve the problem, replacement of the actuator is required. The actuator is on the driver side of the car, near the firewall. You might want to pop the hood, and have someone else replicate the noise so you can more accurately pinpoint the source.
