RADIATOR fluid..MISSING?
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
SUp guys, being new to SC's, i recently gave my car an oil change and when i checked the radiator fluid, it was like there was nothing there, the coolant tank was full, my car isnt making any wierd smells or acting up, but i was wondering if it was a normal thing? or should i put some coolant in my radiator?!
so yea any knowledge you fellas can help me with it would be great!
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
If the reservoir level is not changing, but the radiator level is low, it means (obviously) the system isn't drawing from the reservoir when it should. This is usually because the radiator cap isn't holding enough pressure. Follow what "pcmw" said, and that should fix your problem.
well when i looked into the radiator, usually in my supra, there was coolant that was filled to the top of the cap area, but the sc, there ws nothing, and oh yea the i woke up and looked at it the next morning! so the engine was cold
now im hella worried, but the coolant "tank" in front of the radiator was FULL+
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
