Creaking brakes doing my nut!
OK I'll try to be as quick and concise with this as possible....
I bought an LS460 earlier in the year. Within a few weeks it developed a creaking noise under braking just before the car came to a complete stop. The noise and feel of the creak is almost like the pads are grabbing the rotors during the final 0.5mph of slowing to a halt.
As the rotors were almost totally worn down, I purchased new OEM rotors and pads and went about fitting them myself.
I moved all of the shims over from the old pads to the new ones, cleaned everything up, used copperslip on the shims and the back of the pads and red grease on the sliding pins. Everything was pretty much minty fresh.
This sorted the problem for about a week (until the crosshatching on the new rotors had worn off), but its back again now!
Interestingly, if I do a couple of heavy 60-10mph stops during a journey, the problem clears. Is the issue related to the way I drive the LS? Thought I find it hard to believe I could induce such a problem as none of my previous cars have exhibited the same issue.
Any ideas guys?
Any ideas guys?
creaking or squeaking?
many times, squeaks and squeals can be very difficult to eliminate completely - it is a vibration that is happening at just the right (wrong) time causing the noise you hear...sounds like you have done all the proper prep work for the new brakes...
if it is a creaking, have we checked ball joints and bushings??? torque on the front end can cause a creak when coming to a stop too...
Thanks for the reply
Its definitely a creaking. I did give all of the suspension components a basic visual inspection when changing the brakes as I had though that it may have been a possiblity, but I couldn't see or feel anything obviously wrong.
The same noise can also be reproduced when I'm waiting in traffic and I take my foot off the brake enough for the car to creep forwards slightly. The brakes feel like they unbind from the rotors and then as I come to a complete stop again they grab causing the creak.
All other braking/suspension circumstances are fine:
- I can accellerate or brake heavily with no noise
- Can turn the wheel full-lock in either direction with no noise.
- Turn while going over a speedbump with no noise
It's just when I'm going for gradual, civilised slow-downs without the sudden stop that it occurs. And its driving me mad
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
If at all possible do you Have access to a lift or jack comfortably? Lately i see More and More ls suspension parts make noise i think you..have a case of subframe or lower control arm bushing wear. Ask mitsu guy for his input on my diagnosis. Can you record the noise for me. Lower arm bushings wear the fastest on any ls ever made. Lets start with that inspection. Look for cracking and tearing. And please post a pic of them so i can validate their condition
Better yet are you sure you eliminated your brakes cause your shim kit and brackets arent worn? If they are infact all new did you install the pad wear indicator properly? (squeaker pins) but the best diagnosis to anything ia a proper visual inspection.
Annoyingly I still have the problem. Whats strange is that my car has been in for a service with a main dealer (who collected my car) and has also had an MOT, and neither have brought it up as an issue.
Does your noise rectify its self during a long journey? I seem to find that once the brakes have been used for a while that it magically goes away.
To me it definitely feels like the pads are gripping the rotors, but I also put on new pads and rotors just like you.
let me know if you happen to get to the bottom of it!
what friction material you using? ceramic, metallic, semi-met? if it was ceramic pads then did you follow the brake in procedure? also i dont think this is what your hearing but you might try going down to a local auto parts store (i know napa carry's them) and get some caliper piston cushions. they sit on the piston bore and dampen vibration that alot of toyotas are known for.
Yes, over time the dust covers rip or tear and the caliper piston push pins become dry and noisy. Unscrew the caliper and you will see two dust cover, remove the dust covers, and you will see the long pistons. You can pull those out and grease them with brake grease. Not just any grease it's got to be able to with stand very hot high temp. Lube them real good and put them back together. Do the other side too. Whenever you do a brake job it's always good to not over look this. This often never gets done when people do brake jobs.
apdimitri
Suspension and Brakes
09-08-13 06:07 PM
jaskillz
03-28-12 09:05 AM
