98 GS400 transmission
Re: 98 GS400 transmission
Quote:
Originally Posted by leo723
All my gears work but not the reverse. The reverse only work if I take off really fast pushing my rpm over 4000. I don't understand why but it's the only way it will grab it. If I'm cruising normally and i have to stop and put it on reverse it won't work but if I ref the engine on reverse over 4000rpm then it will grab it but its also dangerous. I did a complete fluid change thanks to the members post but still need help because this problem still continues. Thanks.
I took the advice of the members of lexux club and used toyota t-4. But i belive that your right, i think i do need to rebuilt my transmission. Do you know what kind of kit i may need? Thanks for getting back to me.
Maintenance Moderator
If you don't know exactly what you need to rebuild an auto transmission, chances are it is not something you can do on your own... Plain and simple, there are way too many specifications and tolerances that have to be near perfect in order to make the whole thing work... more importantly than that, identifying the actual problems is the hard part and that takes experience...
ICEBERGS
09-28-09 04:59 PM
ICEBERGS
08-19-09 03:02 PM
