what kind of oil for gs400?
Old 01-05-03, 01:37 AM
steviej
steviej's Avatar
so tight that it won't leak and not so tight that you can't get it off the next time.
I always put the plug in with my hand for at least 3 full revolutions to make sure its not crossthreaded. Then use a standard 1/2 inch drive ratchet, bring the plug tight till it stopped with little to no force, then smacked the end of the ratchet once with the palm of my hand. I've never had one leak in 18 years of changing oil. I'm sure the shop manual has torque specs if you want to go that far.
I have never filled or partially filled a filter with oil.
steviej
Old 01-06-03, 12:02 AM
gebo
gebo's Avatar
Per VVT-i, the oil drain plug should be tightened to 29 ft/lbs.
Old 01-06-03, 12:43 AM
elclassico
elclassico's Avatar
Default did it, no leaks!
do not fill oil filter, some jackass at the autostore told me it was good. just made things a little more messy. besides that, smooth sailing. i just tightened it on there good, not too tight. thanx to all!!!
Old 06-17-03, 01:37 AM
elclassico
elclassico's Avatar
Post with synthetic oil...
i was told change oil every 5,000 miles? anyone know if thats true?
Old 06-17-03, 11:18 AM
Threxx
Threxx's Avatar
Default Re: with synthetic oil...
With a good synthetic oil 5000 is the earliest that it would make any sense for you to change. Realistically unless you beat the living crap out of your car you can wait up to 12,000 miles and it'll never make a difference. After 12k it all depends on your driving habits but you run the risk of starting some damage. It diesal engines it's not all that uncommon to see people running synthetic oil for over 80,000 miles!
TrueGS300
06-25-23 01:30 PM
RamAirRckt
08-26-17 08:29 PM
Loyalone72
06-12-13 05:37 PM
duby1
Maintenance
03-10-10 04:14 PM
TAP4636
02-07-08 09:38 PM
Quick Reply: what kind of oil for gs400?
